01 Front Wheel ABS Speed Sensor
brock71
I have one of the front wheel sensors acting up at low speed. Noticed it first only when turning right into a parking space. Getting worse. Now acts up going straignt ahead.
Read in the forums that an AC voltmeter can test signal output fromthe sensors. I have one.
My question is where do I get at the end of the sensor cable to read the signal? I was looking under the hood for a spot where the cable might plug in. Didn't see anything that looked promising. What about the connector on the ABS unit itself? Pin out?
If anyone has a tip on the best place to measure this I would appreciate it.
John
Follow the wire from the hub, up tho where it goes behind the inner fender liner...there is a plug there.
