Instrument cluster goes crazy Goldilocks issue
eddiep120
I've been putting up with this issue for over a year now, where the instrument cluster will go nuts after the truck has been on for about 30 minutes or so. What happens is, the gauges (spedo, tach, fuel, engine temp) will drop all the way down, all of the instrument lights will flash on, then the gauges will return to normal and the lights will go back off. Initially when it started happening it would only do this once or twice on an hour and a half drive, but became more and more frequent to the point where it looks like the needles are just bouncing and the lights are blinking.
I took note of when it started to occur and it seems to me that when the temperature inside the truck was warm or cold it would begin doing this. If its 40 degrees outside before you start the truck it wont do it until it heats up inside the truck. If it's 30 or 80 degrees outside it'll be doing it as soon as you turn the key in the ignition (even without starting the truck).
When the issue exists prior to starting the truck, when you turn the key it wont start unless you time it perfectly in-between when its flipping the lights on and off. (this is a newer development as this problem has gotten worse and worse). Additionally, when the car warms up for about 5 mins the issue goes away but comes back once it becomes warmer in the truck. When it does this while driving, it doesn't affect driveability or anything (cruise control, windows, locks, radio, lights all work).
I had been willing to live with this issue for a while but now that it's gotten so bad that I have issues starting the truck I've been trying to figure this out. After reading some forums I've checked the battery and alternator. The battery had full charge but tested bad at autozone so I bought a new one but that didn't fix the issue. The alternator tested good. I just got done checking for a parasitic draw but everything looks good (I waited 40 minutes or so to macke sure the antitheft and everything turned itself off and it came up 0s). I also tried jiggling the wires to the cluster and any other wires related to the ignition, tried jiggling the key cylinder as well and nothing seems to recreate the problem or resolve the problem.
Is there anything else that I should check out? At this point should I replace the cluster and see if that was the problem? Do I need to have the computer flashed if I install a new cluster? Is it necessary that I have a dealer reset the odometer on the new cluster?
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
It sounds to me like a loose connection. The part regarding temperature makes it seem more specifically like a cold solder joint or loose connection on a circuit board in the cluster. There are people here who are more familiar with the newer vehicles. Just make sure you include vehicle info such as year and model. More info is better although I don't think engine and transmission info will matter in this problem.
Sent from my SM-G920V using Tapatalk
eddiep120
Thanks for the reply!
The truck is a 2007 Ranger 2WD 2.3L, Manual trans.
I did try banging on the dash while it was doing this, it didn't seem to create any reaction but maybe I just didn't notice or maybe I didn't smack it hard enough.
I'm gonna pull the cluster back out and see if I can find any bad connections and report back.
eddiep120
okay, so I checked the connections on the circuit board and they seemed okay to me but I went ahead and re-soldered them anyway cause it was kind of hard to tell on a few.
I reinstalled the cluster and there was no change. It's cold out right now where I'm at, and as soon as I turned the key the lights were all flickering like I described earlier. They were flickering so frequently that I couldn't get the truck to start until I got a lucky turn of the key.
Any ideas?
eddiep120
Update:
Over the past few days I re-checked all the grounds with a multimeter, they tested fine but I did clean the connections where there was rust and stuff anyway. No change in the issue but with the grounds checking out in the multimeter test I wasn't too surprised.
I've gone ahead and purchased a used cluster on ebay and it should be coming by next week. Hopefully this resolves the issue but if not could this be caused by a relay or something?
I'll report back if anything changes or if the issue is resolved.
eddiep120
Problem solved...
I got the cluster off of ebay and plugged it in - no flashing lights. Plugged the old one back in - flashing lights. At that point it was clear the cluster was the cause of the issue.
I had to bring it to the mechanic down the street to reprogram the keys to the new cluster. If anyone is interested to know, a typical mechanic can't reset the mileage apparently only dealers can do that and it's pretty expensive. I just had the mechanic write down the mileage on the old cluster and the new cluster on the invoice so if I ever need to sell the car the customer will know the total miles.
ericbphoto
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
congratulations!
rdsrds123
2.3
Your problem with the dash cluster seems like a problem I'm having. Has your fix held up? You can see my problem in a post called" wacked out check engine light."
Staff online
Shran
April Truck of The Month
