JMcFly’s XLT Simple Restoration and Mods
Brakes all bled again. I did all 4 corners so I have fresh fluid in the system. I suspect air made its way up into the front of the system when I had the axle out. Pedal feels much better now. I did notice the and light is now on.
I will want to rebuild the front brakes at some point. I have mismatched calipers. One newer and one old/original. Discs are crap, bearing caps are probably leaking.
by this time next year I’ll have the entire suspension and brakes fully rebuilt.
New tires put on and even a matching spare.
Found an original lug wrench, extensions in bag, and document for the jack while at the junkyard dropping off the old rear end. Also got replacement bolts for the seat since I’m missing 2.
Not bad.
Found this randomly and fixed my oil pressure gauge.
Now to figure out why the temp gauge doesn’t move and the blinkers do not illuminate in the cluster.
Do the turn signals work at all or just not turn on the cluster lights? If none of that works, as DUMB as it sounds push the flasher button down like 10 times then push it down a few times while pushing backwards then a few times while pulling back... 99% of the time that gets my turn signals working on my '97... changing the multifunction switch is on the list... usually I can get them working again by just wiggling the button...
I do have turn signals and hazards. I hear the clicking sound and the exterior lights flash. It’s just the cluster arrows don’t light up.
Oil and filter change done yesterday. One of the easiest I’ve done aside from my ‘96 F150 with the 4.9 straight six. That truck I should have kept.
I usually invest in fumoto valves so we’ll see if I get one for next oil change. Since this truck is not my daily I’ll change the oil every 12 months probably. Only not fun part is getting the filter off, that’s an oily mess. I much prefer sideways filters so the oil will drain out.
Starting to plan the rust repair, looks like aside from the obvious headliner removal I might need to take the seats out too. I’ll get a few welding blankets and cover the rest of the interior.
Started taking tint off since it’s failed and purple.
Much better seeing out.
Just noticed this with the drivers seat back. Guess the metal broke at some point. The rest of the seats are in good shape.
:icon_welder:
The back is pretty easy to take apart. Strip it, weld it, and reassemble.
I’m trying to figure out why my temperature gauge never really moves. Where is the sending unit for the gauges temp display? I read somewhere it’s a 1 wire sending unit, I hope it’s not somewhere hard like inside the bell housing, I’m not pulling the trans for a long time.
On the 2.8 and 2.9 it's on the drivers side front down low on the block.
On the 2.5L it's on the T stat housing just in front of the timing belt cover, if the temp sensor never moves it's likely from the heater core being plugged (assuming you don't have A/C) so there's no flow across the sensor, I know this because that's what my '97 does... or did before I flushed the core, still on the plugged side but I have heat for the first time since I've had it...
This is an 02 duratec 2.3L
Dang, that's what I thought I remembered then saw the signature with 2.5 on it...
Dumb thought but do you have anything to read the coolant temp with the OBD II? If so, does that temperature cooperate? If it does it could be something with the gauge or the output from whatever feeds that from the engine computer (body module, gauge itself, whatever)
I have an obd2 adapter and app. I was going to check it out. But I’m pretty sure the gauge should stick around midway when at operating temp
I do need to replace many of the bulbs in the gauge. With 217k miles some things may need adjusting.
