Radiator fail... reliable replacement?
mperry
Springfield, OR
I have a 1994 Ranger XLT, extended cab, heavy towing capacity model with 81K miles. It has the heavy duty radiator for the 4.0L, automatic, and A/C. It needs a new radiator because the upper cooling line fitting and the side tank seal both failed suddenly. It must have been sudden because there was never a spot on the ground but now the 100 degree days makes it leak... and it blew out 3/4 of a gallon of coolant. I discovered the leak only because I noticed the coolant overflow was empty when adding washer fluid... perfect timing. The engine temp meter, as always, never moved above T in Temp on the gauge.
Does anyone have a brand of radiator to recommend? Any brands that have caused anyone a problem? Once the radiator is replaced, I'll go back to getting the AC fixed.
I am amazed at how well this little truck has held up over the years. It's amazing to have a truck that can sit for months then happily fire up when you need to haul something, maybe a 2 tons load, or simply take the dogs to the beach or for a bath. Age wears a vehicle but Ford really overbuilt this guy... though after nearly 30 years it needs a repair every couple years. I bought it with 60K miles 9 years ago (a premium $6500). I immediately did fluid changes, brakes (pads were worn out, but did a full rebuild), "factory" tires (11 years old) and it ran/looked like a 3yo truck. But there's always the little stuff every couple years: left window regulator, thermostat locked shut, right window regulator and door lock actuator, and a 10 yo battery all failed. Now it's the radiator and the AC. (The AC started being less cold last year, doesn't work this year, so maybe has a slow leak?) Oh, and 9 years ago I replaced the factory radio with a new model. It started failing after 2 or 3 months, then fortunately some thief stole the unit since Pioneer/Crutchfield wouldn't warranty it. One less thing.
84tony
30
Charlestown, IN
I would go with an aluminum radiator, there are several on Ebay like this one, for 85-94 rangers.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
6,321
woodhaven mi
FORD mostly
BIGGER
sawzall?
summit ebay and amazon are generally the best deals.
can be risky.
Similar threads
Truck of The Year
Kirby N.
2024 Truck of The Year!
