Leaking Coolant
iamcams
9
Logan, UT
My coolant is leaking from a little hole under the petcock valve. Any help?
Cees Klumper
172
De Luz, CA (near Camp Pendleton)
Bronco II XLT
only lift is from the oversized tires
You might try that flexible rubbery black repair tape that you wrap tightly around a small leak, after which it sort of fuses itself to itself. Hardware stores typically carry it. Let it sit for a few hours before testing it.
rusty ol ranger
2.9 Mafia-Don
9,193
Michigan
177 CID
Ive used seal all (yellow tube about 6 bucks at a hardware store) to seal tiny radiator leaks before.
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
16,837
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That doesn't appear to even be the correct petcock for the radiator. I believe there should also be a rubber sealing washer that it tightens down on.
My Google search comes up with this Dorman part...
Curious Hound
Formerly EricBphoto
21,247
Wellford, SC
6"
Looks like a leaky petcock to me.
Curious Hound
Formerly EricBphoto
21,247
Wellford, SC
6"
Junk Collector
Truck of Month
6,169
Rapid City SD
I've seen those white plastic hex petcocks on several radiators. I don't know if they were the OEM part or aftermarket but they were definitely used in our trucks at some point.
Similar threads
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
