Fuel line...what are my options?
rusty ol ranger
2.9 Mafia-Don
9,260
Michigan
177 CID
rusty ol ranger
2.9 Mafia-Don
9,260
Michigan
177 CID
lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
8,985
Butler, PA, USSA
5.0l
4”
So…
Boiling water and a cold end that you’ve trimmed the old nylon off the barbs works. It’s not the ideal, but it works.
New line and ends with the Dorman tool is probably the best way to go other than going full bore to -6AN PTFE braided line, which is more expensive. I went to the AN stuff just because it can be used for a lot of things. Not just fuel.
Now, that all said, my 92 Ranger someone replaced the pressure line from the pump to the filter in rubber line. But not the high pressure fuel injection line, it was just regular rubber fuel line and it pinholed badly. I needed to fix it quick and cheap. I bent up a bit of aluminum tubing I have (I keep coils of ni-copper brake line in 3/16 and 1/4, then aluminum in 3/8, 1/2, and 5/8 on hand). Bubbled the ends a little, and clamped some fuel injection line on the ends. The 3/8” was a little big, but I was able to work it past the ribs on the pump and the filter and get a clamp on each side of the rib. Bit on the Redneck side, but the lower pressure run on the older trucks it worked just fine.
rusty ol ranger
2.9 Mafia-Don
9,260
Michigan
177 CID
So…
Im going to try the boiling water thing. Since it literally broke right at the barb.
Assuming i can get (whats left of) the fuel filter out of the other end of the hose. Which is what started this in the first place
rusty ol ranger
2.9 Mafia-Don
9,260
Michigan
177 CID
Got it fixed today,
The boiling water didnt work, i ended up fucking up the end of the line worse.
Cut that bad part off, put the fitting in a vice, soaked it in lube and worked it on.
So far its not leaking. I got to drive it a whole 2 miles when it popped a brake line
Project88
11
Virginia
Has anyone ever used AN hoses and fittings on these trucks?
Blmpkn
Toilet enthusiast
8,258
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I'm gonna plumb my 96 with AN stuff, got a bunch kicking around from another project.
I believe @lil_Blue_Ford has the fancy fittings on one of his rigs too..
Project88
11
Virginia
How'd he plumb the line to the rail? On a 2.9
Blmpkn
Toilet enthusiast
8,258
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Youd have to ask him. I've had a long & tiring few weeks... I could very well be dreaming it up lol.
He'll see my tag and chime in at some point I'm sure.
lil_Blue_Ford
Cut & Weld
8,985
Butler, PA, USSA
5.0l
4”
So, I didn’t connect it directly to the rail, I bought the ends that match the fitting on the bit of factory AN going to the rail. Basically replaced from the pump to the braided stainless bit coming off the rail. The rail looks like it accepts an AN style fitting, but it’s opposite of the normal style. I didn’t need to solve that problem because that part was fine on mine.
Similar threads
Similar threads
Truck of The Year
Kirby N.
2024 Truck of The Year!
