lets do the numbers to see if a tc will hold up to 6500 rpm of a motor... i'll use the numbers on my truck, because i know them, ok, a 31" tire is roughly 8 feet around, which means there is 660 revolutions per mile multiplied by 4.1 gears, gives us 2706 revolutions of the driveshaft per mile, now lets figure out how fast it turns, times 60 mph 162,360 revolutions per hour, divided by 60... hmm i think i did more calculations than i needed... 2706rpm is what it sees... that can't be right, can it?
if the motor is in 1:1 gear, and at 6500 rpm, and the transfer case is in 2H or 4H, it should be 1:1 also, which means it's also spinning the driveshafts at 6500, mind you 6500 rpm in 4th gear is a lot faster than 60mph...
off topic, my mustang's transmission, and 8.8 diffs, will hold up to 4000rpm in 0.68 5th gear with 2.73 gears and 28" tall tires... now i'm lost... GWAII HELP!!!!
