- Jul 24, 2010
- Georgetown Ontario
might be buying a lift while im here in the chicago and wisconsin area. will let you know once i know.
Can't wait to see the results! So far your build is looking really good. You've helped me understand my suspension far more than any other person and you explain things really well. Thanks for all the info, updates, pics, and build process.
i got a 90 2wd and i cant find nothing for suspension lifts. and im not doing coil spacers. got any ideas or is my truck just cursed?
What company did you get them from, or were the just junkyard grabs?
To autozone it is then!
coil spacers need to be ductile iron or steel no resi or alum as pictured.
if you ever plan to take your truck down a dirt road or want to jump a speed bump never install lift spindles, your snout will snap and your wheel will pass you pulling into mcdonalds. you also gain no extra travel and lose good down travel as all there doing if forcing the suspension down which brings the front up.
lift blocks increase axle wrap and dont aid in flex or travel.
