first, you need to figure out what axles you have.
for the lift, you need a drop pitman arm, if you want it to be a crawler you need to get some extended radius arms or you wont flex for shit. you'll also need something to lift the rear. the cheapest way is blocks, but again, no flex there plus you'll add axle wrap. if you want flex, get lifted leaf springs....oh and extended brake lines will also be needed.
you could probably run 35's with a 4 inch lift and the bushwacker flares
you're way over paying for those manual hubs as well, you can get them used on here for less than $100 shipped to your door.
I have the Standard Axles, Im gonna swap in 8.8's.
The lift kit from Skyjacker im getting is a 4 inch lift in front and in rear.
Are extended brake lines expensive?
