Bronco II, bringing it back to life.
Charles
1988
I've got a 1987 Bronco II 2.9L EFI 4X4 that I'm trying to get running.
The body is in great shape, but it's been road rough and put in the away in the pasture (almost literally). Anyway, I acquired the thing for free since I have a 88 Ranger that some parts can be swapped with.
Well, I figured, what the hay, let's see what it would take to get it running.
first things first.
I checked the oil, it was stated that it had just been changed before being parked. It looked surprisingly good, not black, looks like oil right out of a brand new bottle. but seems to have a little too much in it. Just seems like there is too much oil on the dip stick.
there is fluid in the radiator.
It wouldn't run hardly at all, would stall, and eventually just spin.
I removed the gas tank, cleaned it up, reinstalled. Changed the fuel filter, changed plugs and plug wires. belts were shot so I changed them out.
The exhaust pipe was...well, someone looks like they've tacked a flowmaster or something on it. not a very good job, and no pipes coming out the back.
Anyway, turned it over and it started right up. Ran rough as hell though.
first thing I noticed was exhaust smoke coming from the passenger side around the back of the engine. This happens immediately after starting.
Also, a few vacuum lines were broke or disconnected. I went by my Rangers engine and rerouted some of the vacuum lines (someone had routed them different than my ranger) and it improved it. There are a few differences between the two though, the Bronco seems to have a few things the ranger does not have, so I have no idea where the lines go, if it matters, etcc.
The oil light on the dash flickers on and off and the engine sounds like it's ticking pretty loud.
I didn't leave it running long, just long enough to start it up, check the vacuum lines to see if it ran better/worse and shut it off.
Any suggestions on where to go next?
I'd like to post some pics and maybe someone could help me out with the vacuum lines. The exhaust coming from the engine compartment and getting into the passenger compartment bothers me because I can't see where it originates, but it's pretty bad. any suggestions there?
The oil light flickering, I plan on dumping the oil and oil filter, but I think it was stated that the oil light has always flickers. Oil pump maybe? hard to change that?
The ticking? Lifters? valves? what should I do there?
Any help or suggestions would be greatly appreciated.
Its a 2.9,get used to the lifters ticking. It happens.Might try a thicker oil. The passenger side exhaust manifold is also good about breaking.
the smoke could be from the valve cover gaskets leaking oil on to the manifolds and causing smoke. happened to me before
Thanks for the replies. I'll take a look at the manifold to see if it's damaged or if it has oil on it. The drivers side Valve cover looks like it was removed at some point, thinking the gasket was changed, but they didn't tighten the bolts down properly. hope they didn't strip them. I'll probably go ahead and change them at some point.
What I'm trying to do is get it drivable, but I have to watch how much money get's dumped into it. at some point, it's wiser just to replace something as opposed to repairing it. so If I'm dumping money into it and find something major.....well, lost alot of money.
Where is a good place to look for a complete exhaust system and about how much do you think it would run? Local junk yard is pretty good, but very pricey. It's the only one around and they do not allow you to go into the yard, and they are not open on weekends (shows how much money they charge if they can afford to be closed on the weekends).
Just for the heck of it also, how much would a rebuilt motor cost and where would I look for one of those?
It sounds to me like the motor is shot. If the oil light flickers on the dash, when it's cold, that's a very bad sign for that motor. Lifters will also tick when it's low on oil pressure, but on a 2.9L they have a propensity to tick anyway.
What I would do at this point, if the rest of the vehicle is worth it, is go to the junkyard and get a motor. Rebuild one using the better parts from the other. Examples would be the crankshaft, valves, cylinder heads, etc. Try to get an '89 or later motor, since they had the improved heads.
Edit: I re-read your original post. Try to find out why the oil light flickers on the dash first, before you do anything else. Better yet, get a mechanical oil pressure gauge and see how much oil pressure it does have.
What is this item in the picture and where do the red and green lines go?
On the Bronco II, the green line is broke and is hanging loose.
What about the other items? Which vacuum lines attach to them?
For now, I simply grabbed some clean fuel line I had laying around and hooked some of them up, so ignore the color or hose type.
If your looking at an engine swap,you'll want to look at finding a wrecked explorer and put the 4.0 in.You'll have top swap engine, dash and wiring.Its not as hard as it sounds.Go checkout the tech library.There is a lot of info on the swaps and 2.9's in general
The thing in the first (from left) picture is the EGR solenoid. The red line coming from it is supposed to go to the manifold where the neon-green line is in the third picture. The other line, the black one, in the third picture, is supposed to go to the MAP sensor, which is shown in the 5th picture with neon-green line hooked up to it. The dark green line in the first picture coming from the EGR solenoid is supposed to go to the open port on the EGR valve, as shown in the second picture. The line in the 4th picture is ok, as the fuel pressure regulator is supposed to be hooked up to manifold vacuum.
I went by color as that's what's in your pics. That should explain where everything's supposed to go. Be careful with those plastic lines as they like to crack and leak.
Thanks! That gives me something to go by! I've got two more though....
The second picture...under it (can't get a shot at that angle) is a broken line, in between two large lines. One large line goes to the PCV valve, I forget where the other goes. The one in between is broken.
What about the line from what I think is called the charcoal box, or something like that (first pic)
on the charcoal canister, the thicker line should step down in size with a metal line, and then run to the bottom of the throttle body. from the sounds of things, this one might be one that you say is broken. the other line on the charcoal canister runs to a vent on top of the fuel tank.
Cool, thanks everyone for posting. I'll take a look tonight. I really do appreciate everyone's help and suggestions on this.:beer:
Are there any other vacuum lines I need to be aware of? mostly all the lines were broken, and some were just hooked up wrong. I have no idea what the original owner was thinking.
The red line coming from the EGR Solenoid, it has a "T" in it, one end of the goes into something mounted by the Air Filter box. What is that that the other red line goes into?
Also, at the back of the air filter box is a larger hose, on mine it was disconnected and goes to nowhere. where does it go?
doesnt go anywhere specific as far as i know, just toward the firewall and as high as possible. since the air inlet is so low and could draw in water, ford put that there to make sure if the inlet did get submerged, it could pull air through that hose and keep the engine from sucking in water
Played around with the vacuum lines tonight. The more I play,replace, and upgrade, the better it runs. Still got a few things to do, but I can drive it several miles back and forth up a back country road no problem (so far).
Oil pressure light doesn't come on until the engine get's warmed up. So when I first turn it on, no light. After running for 5 minutes or so, it'll start to flicker.
after driving it down the road and parking it, the light will stay on but it will go off if I drive it again (Higher the RPMs, the light will go off, lower the RPMs, it stays on).
Anything I can run through the engine to try and clean it out? Thought about Sea foam, Someone stated adding a little transmission fluid to the oil, running a little, then changing the oil. A few other suggestions like kerosene or something (I've never heard that!).
I'm moving forward, I don't want to mess anything up.
I'm gonna check into the mechanical oil pressure gauge sometime this week coming up, but are you talking about a simple analog gauge you buy at the store or something else:
http://www.google.com/search?client...1024&bih=575&bav=on.1,or.&fp=ca3424583e0d5426
And if so, how are those installed?
In your motor Charles, I'd run a synthetic 5w50. Once the oil warms up and thins out, the pressure gets too low, and the oil light comes on. That means the motor is worn out. You therefore need a thicker oil when it's warm to compensate. This will work in the short term; in the long term you need to rebuild it.
From the way you describe it, it sounds like the oil pressure light is working properly. However, if you want to know for sure (I would) then see this link:
http://www.therangerstation.com/Magazine/Spring2003/oilsender.htm
