RaceRangers Build
Got all my parts ordered up for my 9". Cant wait to have it under the truck, going to build it over the course of next week. whent with a 5.67 ratio, should put me about 4k rpm at 70 and 5k at 80 not using overdrive. This set up is good to around 1200hp with the 35 spline axles, so i dont think i will be breaking this thing anytime soon.
RaceRangers Build
RaceRangers Build
you should be set with that...alot of beef
Truck is lookin real good. Is it difficult to drive without the power steering pump on there?
its tough, but I plan on putting the pump back on and add a power steering box when I do the x-over steering set-up.
Are u going to add ram assist? Looks good man. When ya gunna link it?
probably not, but power steering will be alot better than manual though. I will hopefully link it sometime after huckfest. I have been thinking about doing a core style link setup like Steve Herrera's Race truck.
Cut the tubes for my housing, 3 1/4" o.d 3/8 wall. Quite Beefy.
RaceRangers Build
just went threw the whole thread, love the build, keep jumping the $h%t out of that thing!
so your re-tubing a stock 9 inch housing?
Yeah pretty much, we shove the new tubes in a lot farther than stock though. Almost to the carrier bearings.
Whent to the Battle at Primm race last weekend, had an awesome time and def got me a lil more motivated on the ranger.
Got my shifter mounted and shifting correctly finally, also wired my fan and made a new sheet metal cover for the trans tunnel.
also did some more work to the housing today
RaceRangers Build
RaceRangers Build
My Girlfriend bought me this wheel along with at quick disconnect hub for the truck. May be putting it on here soon.
RaceRangers Build
thats the same wheel i have in my truck, i like it its nice and comfortable but with no tilt wheel i cant see the top of the speedo without slouching down a little...
but im also in a single cab so its tight in there
Well soon enough my guages will be In the center and my speedo will be on gps
that would be nice.
so your going with regular 9 inch outers? i see a rear spindle in the back ground, didnt know if you were going FF or not
