- Nov 26, 2009
We are also comparing a SBC vs a SBF swap here too...
it is not that simple, more than just an sbc swap i am running on a shortened chev truck frame that is why all of those other components i listed were such a perfect fit......chevey designed them that way.
CAMMEDDRZ--Sorry to Hi-jack,....BUT,what did you use to cut out the firewall and did you have to use secondary cab support? What problems did you run into doing it this way? Kinda intriged here !
i used a cut-off wheel on a grinder, i then patched it from inside the cab after the engine was in and done.
that greenish/tan looking stuff you see through the holes is the factory foam insulation
He needs to do neither to change the power steering pump.
I removed the metal necessary to fit mine in the support and nothing bad has happened in the ten years since. The front end hasn't collapsed as a result from it.
You're completely "off base" here in making that comment.
