- Aug 7, 2007
- Opelousas La.
why would you replace a fuel injected 4.0L V6 with a carb'd 302? Unless you plan on making alot of mods to the carb'd V8, you are going to be roughly the same power wise, have a heavier vehicle, less throttle response, and use more fuel
Eveything you posted here is crap.. Same powerwise ? No, the V8 produces more torque. Heavier vehicle ? Not that you can tell, there may be 50-100 lbs difference. Less throttle response ? NO. Use more fuel ? Not much difference if any between a worn out 2.9/4.0 and a carbed Explorer V8. Mine gets 18 mpg highway without overdrive.
