bigmark303
I found a wealth of information on the front wheel bearing issues of the 4x4 Rangers, but nothing if there is something about the rear wheel bearings on a 2wd.
I have two 1997 XLT 2wd Rangers and the wheel bearings are not bad from what I can tell but just loose and wont stay tight. I am running 26-27 inch tires on the rear with 16 inch by 7 inch Lincoln Mark VII wheels if that means anything?
Im pretty sure they are not bad, but they are always loose on both trucks. Any info will be greatly appreciated.
Thank you.
Thank you.
