- Oct 27, 2007
- Fort Wayne, IN
probably just another one from a junk yard. Thats the least of my worries. Need to find a motor first
Hopefully its not your gears making sounds on ya. I would check the gear lash on it hopefully your pinion nut hasnt backed off on ya. Mine growls but those are just my bearings just needing warmed up, getting new ones this summer.
I will say I loved the snow we got, going to go have fun in a bit.
You are prolly goin to get alot of questions from me. What is the measurement on the shackle from bolt hole to bolt hole if you dont mind? Tryin to figure out a rear lift setup. Goin to run a 35/36 tire and the 4.5 or 3.5crawler coil spring for a 66 to 77 bronco. Im goin to do alittle cutting also on the fenderwells.
