Some updates.
I got some parts from the powder coaters today. Im all about having clean parts and i powder coat everything. Plus i want to go though everything to make sure it was in good shape.
Powder coated my calipers, spindles, gun metal and my rotor shields black.
I needed to make some steering extensions. I extended my arms 4" so i needed to do the same on them. It was easy, just thought id show you how i did mine.
Here are the stock adjusters. The bottom one i cut in half.
Next i cut some 90wall DOM tube 5" long and set the adjuster 1/2" in on each side (to make my 4" extension.
All welded up. I ran out of gas and had to flux it up. I made sure to slit tube i added in the same area the adjuster were.
Then i had them powder coated gun metal and the clamps black. Easy as pie.
What a weekend.... My ass is offically kicked. FYI always rope a buddy into helping you with a major project....
Now on to the good stuff. I took some process pics. Most of you know how to do some fab work or have made or installed a front end. But some havent.
I removed all the stock suspension on the drivers side. I removed the beam, radius arm, spindle, brake, and tie rod. So i was just left with the coil bucket. The best way i found to remove the rivets was just a angle grinder with a 40grit sanding wheel.
Get all the way down to the metal on the bucket. Dont forget about the 2 rivets under it. I used a big pry bar to remove the bucket.
Grind the bodies of the rivets down to the frame.
Then knock them out with a hammer.
I cut my the shock side of my coil bucket off and mounted it to mock up my shock tower.
I wanted to have more travel so i added a F250 shock tower. I just cycled my suspension to get the right spot and welded the F250 shock tower to my original coil bucket. Next i drilled some new holes for the shock side. I used 1/2" bolts. The F250 shock tower is pretty long (i cut about 6" off). So its great for much bigger shocks. The pic below i kinda jumped ahead. You can see the shock tower welded to the stock coil bucket them bolted to the frame. In the pic as you can see i have everything bolted in on the drivers side.
Another shot with the wheel installed.
Here it is in all its glory. I have positive camber because i was checking the droop for limiting straps that i need to order.
I also cut off the frame brace / pitman arm guard. Looks 100 times cleaner.
I finally painted my fenders.
Some of you guys were asking about the tire gate i made. Sorry for the bad pics it was dark. Ill take some better pics of the truck and tire gate in the day time.
Well all in all it came out nice. Rides good. Im going to get and allpimgment tomorrow. Im pretty proud that i built my front end. I think its going to do just fine. But i think im going to go with some coil overs in the next 6 months and make some nice radius arms. Next is the rear. Im going to do the shackle flip with some F150 leafs. Im going to make new shock mounts and relocate the passenger side to the rear of the axle. I wish my tires would wear out so i can get some 33" Grabbers. More soon....
~Shawn
