bobbywalter
TRS Technical Staff
TRS 25th Anniversary
Ugly Truck of Month
- Aug 9, 2007
- woodhaven mi
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
I typed out a whole big long explanation just now and the internet locked up so i am not gonna retype it all.. My point was that my 2wd will wheel better than most stock 4wd's. I personally haven't seen many stock 4wd's that are very off road capable.. I mean other than like a jeep rubicon or something, they are pretty sad... And my truck even now the way it sits can do MANY things that MOST stock 4wd's can't do... Obviously there are things that they can do that I cannot as well.. I am saying, I have a lot of clearance and great tires... My truck will be capable of wheeling better than basically any stock full size 4wd vehicles (f-series, silverados, rams, suburbans, etc)... Which means it will wheel better than MOST 4wd vehicles on the road.. Probably even do equivalent to or better than a non-locked wrangler etc... That is all.. And I have been to the rubicon but it has been years... And I OBVIOUSLY would not be able to make all the nasty stuff.. Probably none of it.. I just want to do as much as I can and see how I do.. And I know you will still disagree, but.. I have already done many things that many stock 4wd's can't do strictly because of clearance alone..
well, if your crossing a 24 inch log and have 25 in of belly height and 35 in tires and i am in a stock chevy pickup, i guess you would go farther if it wasnt too slick and uphill and i would have to hurt the stocker to try and pull it off. so situational i guess i am wrong. its concievable in some extreme case of testing if the tire and clearance is huge on the 2wd.
i tell ya what. come to hollister in march. i will likely be there....i may possibly be in jv in feburary....if i go to jv i can try to rent a 4wd critter...like a vitara or something.
thing is....there are many ways to gain traction when you can pull both ends. and i will use these to my advantage.
dont know when your con run will be, but i would like to see it compared directly to a run of the mill...bone stock sami/tracker type thing or xj...even a s blazer or ttb explorer. it really would be interesting.
