ForOffRoadDriving
On the bumpers i used 5x2 channel and then lipped the angled cuts with 1/4x2 flat stock to keep it ridgid. The looseness im getting in the wheel seems to be circumstantial to the road im driving on. If its got a lot of crown then the wheel needs to be turned to the drivers side to keep the truck from turning to the passenger side and into a ditch. When going straight on a flat road the wheel is centered but if i turn the wheel to the left or right just a bit it will turn instantly. Im going to try to get a bettter pic of the tie rod angles with more sunlight today as im leaning toward steering angles as the cause of the lazy steering. I was thinking the other day and if it were my caster that was bad then the wheels would have trouble returning to the straight position after turning but it does have this condition. Maybe i just need a new mod to focus on so i can leave this alone?
