Excuse me, didn't realize that I was using for my own entitement. I was just trying to use a little humor to get my post back to the top after a day and a half.
Don't worry, I took that as a humorous statement.
I have a similar problem. I have had no luck making a positive diagnosis. When I start my Explorer, it starts normally and runs well for several seconds. Then the RPM dips, the engine starts missing, and I need to blip the throttle to keep it alive. Once I give it a little gas, it stays alive on it's own but misses and runs at a low RPM. Once the engine warms up, it runs fine. My engine is not throwing a code at that time. The problem occurs most/worst when it's cold.
I have checked or replaced: MAF, IAC, O2, plugs, injectors, and more
I rebuilt the engine about 2 years ago. The rebuild included hot tank and honed block, ground and polished crank, new rods, pistons, seals, main & rod bearings, gaskets. I had a shop do a quick visual inspection of the heads, and they said they were "useable."
I think that I may have a leaky valve stem seal. When the engine sits it causes oil to leak down and pool on top of the valve. When I start the engine, it runs normally for a second or two, but then the opening valve releases the pool of oil into the cylinder, fouling it. After the engine runs a bit, the oil is burned off and/or exhausted and the cylinder is unfouled. This explains why my engine with a brand new bottom end burns 1/2 quart of oil every 3000 miles. Is your engine using any oil?
