Hey guys I just got an 88 stx High Ryder with the 2.9l and it needs an oil change. I was wondering what oil and weight everyone is using? Also what spark plugs? Thanks!
I use whatever is on sale.. I keep it in the engine for 6 or 7,000 miles and then put whatever is on sale at that time in it..
All oil is so close to the same that I see no difference in it.
No reason to use synthetic oils. They do NOT lubricate any better than standard dino oils do.. ALL synthetic oils CAN DO is resist higher heat than our engines can produce! Standard oils do just fine in our Ford engines.
Big Jim
Jim, there are major differences between synthetic oil and regular oil. I think you might want to do some research on oils.
On another note do you need snythetic oil in the 2.9? If it was not designed to use it then no. Motors that use synthetic oil have tighter clearances on main and rod bearings, rings, seals an so on. Most engines that use synthetic oil will be hurt in the long run due to using regular oil.
Thanks for the input guys.
Jim, I would like to hear what you did to research this. I'm not trying or wanting to create an argument so please do not take any of this in that direction. Either myself or you are miss informed about synthetic oils. I would love to be proved wrong so fill me in with what you know.
Ok you know the gizmo with an electric motor, a bearing, a small dish to hold oil and a pressure bar to load the bearing... I'm sure you have seen one. You can test oils and additives using this machine.
Synthetic oil wil out perform regular oil hands down no questions asked. It will take twice or even three times the load of regular oil before it locks up the bearing.
Sure it will...However that LOAD isn't inside our engines! Regular oil will withstand ALL the loads our engines can provide.
So if it takes two or three times the load it has to withstand heat better and lubricate better. You can not have one without the other if the oil withstands heat better that means it lubrciates better.
Again you are correct... However none of that load nor heat is there for it to withstand.. so the lubercation is zackly the same as regular oils.
Facts:
Regular motor oil does not retain its viscosity like synthetic oil does. It becomes very thin under a lot of heat and stress.
Yep! But not inside our engines! That "lot of heat and stress" just don't exist in our engines.. so the viscosity of regular oil remains good.
Regular motor oil clumps together in cold weather making it a lot thicker then it's viscosity rating on the container.
That's zackly WHY there is a viscosity rating on the container! It's there to tell us just what happens when the oil cools and what happens when it gets to temperature. Them ratings are correct. Advertising by synthetic oil brands to the contrary are simply LIES!
Synthetic oil is a cleaner finer oil.
Nope! All oils have in them zackly what the oil company wants in them. As for "cleaner" I wonder who found dirt in their refined oil?
Synthetic oil retains its viscosity better in cold weather and even under high load and high heat.
As stated above them high loads and heat you mention simply aren't inside our engines. YES synthetic oil will do things regular oil will NOT do! However, there is no use for it in our vehicles.
Have I ever seen anything that says "DO NOT USE ANYTHING BUT SYNTHETIC OIL" honestly yes I have. I will gladly go into more detail with that later.
Get two quarts of oil..one reg. oil one synthetic and put both in the freezer and after a few hours see which one pours easier.
Don't bother arguing with Jim, he's arrogant and always "right".Jim, I would like to hear what you did to research this. I'm not trying or wanting to create an argument so please do not take any of this in that direction. Either myself or you are miss informed about synthetic oils. I would love to be proved wrong so fill me in with what you know.
Synthetic oil wil out perform regular oil hands down no questions asked. It will take twice or even three times the load of regular oil before it locks up the bearing. So if it takes two or three times the load it has to withstand heat better and lubricate better. You can not have one without the other if the oil withstands heat better that means it lubrciates better.
Facts:
