My 91 Exploder
on the cheap
Lol thats me! My only problem is that its my DD also and I want to be able to use 4wd on the road when it gets icy.
how long has the lincoln lasted for you so far?
wow man impressive work! thats one of the coolest, meanest explorers ive seen!
and u like to break stuff a lot i see LOL
keep up the great work!
Its been long gone. When I did the big lift and 4.56 gears I swapped in a ARB in the front and broke it and now I am on a powertrax locker.
Got a package today from the big brown truck today.
Wonder what this could be?
JD bolt on trac bar mount???
l8r, John
Hey Foxracin I got a few questions for you. How much did the JD trac bar mount cost you and is JD going to add this to their website?
Is there any word on if they are going to have a complete kit for sas or just piece one together?
I really like your build on your 91. I got a 94 Limited that is always a work in progress when I have the time or money to do it. Sas is my future project ........ just have to strip my 79 Bronco axles rebuild them and get all the other goodies for the sas.
I'll answer this for you. Technically it's not a JD trac bar mount. It's a ThatGuy trac bar mount.
I built it for him. Yeah I was at the JD shop and I used their welders and shit to do it but it's my design. I took my trac bar mount off and built a jig from it and then used that jig to build Trevor his copy. I offered it to JD to use but the word is still out on it right now. I have spoken with Suzy about putting the trac bar mount into production several times but to be honest, the Duff shop is seriously backed up right now.
What he said^^.
ThatGuy FTW!!!
Let me know when you want to swap yours to a 5 speed and we will get er done.
mmm, gettin closer.....there are tons of SAS's goin on right now and im antsy to start collecting parts
Sweet ass! Where'd you get those? I know someone that is looking for that exact setup right now!
I also just learned that JD changed their buckets a little bit from the design I have. Seems they took a tab off the front side on the frame part. On the trac bar mount you will need to put a washer or two between the front hole and frame. Once you get your buckets, you'll see what I'm talking about.
Event Coverage
TRS Merch
