If you can afford the extra money, get the 20 ton, its much sturdier and has more capacity. Im sure I could do at least 6" of 1/4" in my 12 ton with my setup though.
Yes, a mason jar and air line fittings with silicone caulk to seal the fittings to the lid.
Richard
nice edge.that reference line is pretty much a must to get an even grind.
looking forward to seeing how the lower die turns out.
beauty!you wouldnt get better bends from a professional fab shop.
i do have one concern,though.there are huge forces pushing outward on those lower tubes,and as strong as the welds are i would put some narrow flatbar from the bottom of the tubes to the base to gusset it some,or you may find that the lowers start to spread apart.you don't want a weld letting go when there's 12 tons(remember,that's 24000lbs)pushing on it.
i would also put some more bracing on the top plate,as it will start to bow over time with all the force in the middle,but a load going to the ends.
not trying to be critical,it looks great.just want to make sure it stays that way in the long run![]()
