Well the Sploder has done nothing but gave problems the last week or so.
Went wheeling Saturday and the water pump started leaking out the weep hole. Got it sunk it up pretty good in a mudhole. Did fill up the passenger side inside with water again so I got to try out the herculiner on the floor board. Just pulled the plugs and rinsed it out with a hose. Lot better then the carpet was.
Here is the mud hole. I know for a fact there are 44" ruts in this hole and I was going the hard way trying to get up the little ledge. Would have went the opposite way no problem. Pay attention to the video when its winching out and you can see the clutch start slipping and see it smoking it.
http://www.youtube.com/watch?v=RgkBrbqbSSQ
Got mud/junk/grit in the clutch keeping it released. Wouldnt grab all the way. Limped it back to the parking area and got a water hose and sprayed it through the inspection hole while pushing the clutch in and out and finally got it all washed out. Back to normal now. I thought for sure I was going to have to put a clutch in it.
Then the idler pulley started raising hell again. Its not even a year old. I know the mud aint good for it. But I fixed it for good this time. Just took it completely off. Didnt really see a need for how it was routed anyway. Belt is still plenty tight enough and plenty of wrap on the alternator. One less thing to worry about.
Got the water pump pulled off today and one bolt had to just break off. Just enough to piss you off. lol
Couldnt get the clutch fan off either. Broke one of the tools trying to get it off. Have another one to go on it anyway since the other fan blades looked like they were about to sling off. So I left it on the pump and had to beat the pump into about 100 pieces with a sledge hammer so I could get the pulley off since it was all I needed. Put all the pieces back in the core box to take back to Oreilly and see what they say. lol
Flushed the radiator and cleaned the fins real good and flushed the engine. Going to try to get the broke bolt out tomorrow and put it all back together and change the thermostat while I got it apart and fill it up with some fresh antifreeze.
On a good note did get a new muffler today. Got a Flowmaster 50 series to quieten it down a little bit. Going to try to get it put on Friday night.
