35X12.5R15 Yokohama M/T
WoodyB2
Vancouver,WA
I know that slo-vo is running a set of these, and was wondering if anyone has any reviews of this tire.
thanks
Work better backwards. And not a true size tire either. 33 will be 32 and 35 will be 34. Spend a lil extra money and get a better tire.
I've never had any tire measure out to true specs. Usually 1.5" short or so...
1½" is a lot... what tires were those? (I don't think even the old-style Goodyear MT/R was that much too short)
My 35x12.50 BFG MTs measured 34.9" at 30 PSI when they were brand new. The new-style MT/R Ks seem much truer to their stated sizes also (a very-slightly-worn 33 looked to be right about 32.8").
Thanks for backing me up.
Let me rephrase what i said earlier. MOST tires will be within 3/4" on the correct rim and correct air pressure. Every now and then you'll get some that will be oddballs.
acutally interco usually runs slightly bigger than printed size so most tires are definately not 1.5 inches smaller
Intercos, BFGs, Wildcats, Pro-comps, ect. Most are around 1" short, my Wildcats and Intercos are 1 1/2" short...
How are you measuring those? Because I've never once had a BFG tire more than 0.2" shorter than stated size (31x10.50s, 32x11.50s, 33x12.50s and 35x12.50s, all mounted on the rim and inflated to around 30 PSI).
every interco tire i've ever owned was taller than advertised. BFfg's always measured out close. Even my baja claws were taller than stated. never had wildcats or procomp.
