front and rear axle ratio swap
dangerranger10
Ok so i have a 86 Ranger 4 wheel drive 5 speed with a 2.9L V6 and I use it as my work truck. I mean I'm always pulling a trailer or something with it but I have one problem. The gear ratios in it are 3.45 gears and it is too hard to keep it running without constantly clutching it. I am wondering about putting either 3.73 gears or 4.10 gears in it. I drive a toyota for work that has 4.11 gears and it seams ok. I want the truck to be able to idle around in at least 1st gear without me having to either hold my foot on the throttle or ride the clutch but I still want it to be able to run pretty fast. I run 235/75/r15 tires on my truck also and get about 25 mpg.... i dont want to drop below 20 mpg but i need some better pulling gears........i can drive in 4th everywhere i go as its geared now and i would rather need 5th just as long as i can still go 60 to 65 mpg when needed like on the interstate because i drive my truck everywhere. I had a 92 ford ranger that had the 3.0 but it was about blew up and i could take off in 2nd yet still it ran pretty fast so would that be the 3.73's or the 4.10s?
Holy run on sentences batman.
Ok....I would suggest finding an axle with 3.73 gearing. That should give you a little more oomph, while keeping the MPG's up. I would only suggest trying 4.10's if you plan on going to a bigger tire. Not to mention it will be much easier finding 3.73's than it will 4.10's.
Nate
With that 2.9 and you doing a lot of towing, I'd go for the 4.10 myself. I had a '98' with the 3.45 gears and it would fall on it's face on the interstate in a slight wind up a little incline.
Dave
Back when I was still running a 2.9 engine I was also running 235/75-15 tires... and with 4.10 gears my best mileage was 26.2mpg and I could consistantly get 23-24mpg running locally
And that was running at 75mph acoss pennsylvania on I-80 with my air conditioning on full blast...
So I'd strongly recommend 4.10 gears with your combination.
I DO NOT recommend 4.10 gears with the same tire size if you intend to cruise faster than 65-ish with a 4.0 engine, the 4.0 simply doesn't like cruising faster than 2400-2600rpm, it gets progressively piggier as rpm increases.
the 2.9 seems completely happy cruising even at 3100-3200rpm for hours.
Just avoid the rpm where the 2.9 tends to produce the "cologne drone" at ~2900rpm, either go faster or slower to avoid the noise.
AD
