damn, that thing looks good, got a question tho, what gears are you running? stock 3.73's? i'm putting 31's on mine and i have 3.73's, and i wanna know if the 2.9 and stock gears have trouble with the bigger tires.
i just have two ?'s for you
why did you reuse the d28 all the brand new parts and use a piece of shit for a front axle and the second why the hell if you are lifting it would you reuse the auto hubs they suck please change them at least
ok cool, i was a little worried about it
yeah, i wanna regear too, i'm just going to 4.10's tho, i think 4.56's would be overkill. once you put the k&n filter back on, you should have a little better acceleration. i've had one on mine for last 7 or 8 years and acceleration is WAY better than it was with the stock box
Yeah I think 4.10s will be perfect for you. I saw in your build that you have a manual so even with the 3.73s you wont be to bad. I plan on putting the K&N back in. I'm going to try and find a place I can get some aluminum sheet metal an build a heat shield then I'll open the exhaust up a bit with a Thrush welded muffler, then look into getting some pacesetter headers. How do you like your set??
Hey that is looking good, very clean BII!
how is the lift, i kinda want to lift mine more but i am short on funds.
can you measure your rear driveshaft length for me? i'm trying to figure out if i am going to need to get mine extended. i have a james duff double cardan joint driveshaft and it extends, but i wanna see if i will need it to be any longer. thanks
ahhhh, yeah, i forgot you had an auto tranny. well good news is, my james duff shaft is a shade under 33" when fully extended, so i think it should work when i lift mine. i'm only gonna lift mine 3" in the rear anyhow, i have a shackle and i'm gonna get an add a leaf or a 1 inch block. thanks a lot for measuring that![]()
