^^ you almost have it all right. more then most.^^^
the dumb ca smog laws are:
1, must be the same year or new motor from the same manufacture.
2, motor can come from a different model of vehicle but not from a "heaver" type of vehicle. IE: can go from a mustang to a ranger but not a 1/2 ton F1 to a ranger.
must transplant everything "smog related" from the cats, type of fueling system (like charcoal can) and everything else that’s on the motor from the factory.
3, trans are open for any.
there whole thing is that a newer vehicle is suppose to be a cleaner running vehicle so that’s what they want. when they open the hood, they want to see it as the vehicle where the motor came from with out any mods so they can not tell the different.
after you get it checked out through the state ref., they will put a new "motor" ven number tag on the vehicle and it gets register with that number. from that point on, you can just go to any smog shop as needed.
One of the problems with state refs. Is that you have to pay each time you go and most of them will change or add things for you to do each time you try to go. It takes at least 3+ times before you could even think about passing. Once you go and you don’t pass, your label as a “gross politer” they revoke you reg. and you have to go to the DMV and get a “temp. pass” sticker you have to put on your car if you want to still drive it. The temp pass are good for about 3 months.
It really does suck in soca. Be very careful to not let the smog nazi (CARB) come in your state.
Can the mods of this board move this to “other swaps” I am new and this may have been posted over there.
