another A4LD problem
Funnyman141
Fort Madison, IA
Well my '93 exploder has the Auto tranny :bawling:
So far I filled it with fluid so it's up to where it should be I hopped in it ran it through all the gears a couple times then put it in 1st to see if it would move well it did but not much. So I tried drive same thing happened I put it in overdrive it doesn't move at all, it pulls forward in neutral and park also but in reverse it doesn't move what does this sound like to you guys?
I really appreciate any advice/help/cookies you could send my way
yea I know but it still pulls forward in first and second like its not shifting, if the cable was that far out would you still be able to put it in first?
why did it have to be an A(wful)4LD?
after reading the a4ld problem thread some people are having problems with it puking the fluid out of the overfill so why don't they hook up a overfill bottle kinda like the coolant tank?
The forward clutch is welded together, that's why it pulls ahead in N and wants to in P. Won't move in R because the forward clutch isn't suppose to be applied in reverse.
