I am NEVER Wheeling AGAIN.......
why do you think that?
because even whn i adjust the driver side inner tie rod in all the wy it is still about an inch too long , and i have yet so see if i can adjust the passenger side enought to bring the toe back in , it would make sense that if whenb they used that front weird crossmember triangle shaped thing to pull me through a mud hole that when it pulled the center of that forward , it pulled the frame rails in , which would pull the axles in and push the wheels out , or i just really screwed up all my brand new steering components , which i highly doubt
BUILD... BREAK... repeat...
Aint fun unless u gotta trailer her home. I feel ur pain tho
gotta get some proper tow points up front. so what ur saying is the frame rails are like /\ ? the top being the front of the truck. if so can u get a high lift and spread them back out
________
Prilosec Lawsuit Info
that is what i am thinking , but now i have some numbers to go by
EDIT: i just went out and measured the front end and it is still perfect
well it is always 1step up .5 step back what can you do. atleast you are making headway
well i still have to figure out what is throwing the steering off
home made bumper straightening
^ lol I did that to a few rides of mine before whatever works right mine finally broke and I need to straighten my rear bumper
well i got my steering linkage all straightened out , it was a bent component , i blew a brake line , and in doing that i completely screwed up and now have to run a line from the MC to the left front Junction Block , from there to the RF wheel , and one from the MC to the Junction on the grame for the rear
your doing good work man
sweet. then get that 4bt haha
yea , that 4BT is on hold until i get my 2000 done , and that is gonna be the end of the summer probably , i have 3 projects ahead of it , well actually i have 3 of my family's vehicles first , i have the 2000 and 2003 cadillac's i have to switch the front seats in , the 1976 Corvette i have to fix the brakes on and replace the U-Joints in , and the 72 Chevy Pickup i have to do a tranny swap in , then i get to put the drivetrain in the 2000
