solid front axle
green_duck42
New Hampshire
Does anyone know what the last year ford stopped making the ranger with a solid front axle?
never, unless you count the older 70's fullsize trucks with the ranger trim.
i thought the first series had a solid front axle...if not the first two series and im talking small ranger not the package option for the f100 or f150
Nope, it was TTB up until 1998, then it went SLA IFS.
This is a long shot, but maybe you're thinking of the Ford Courier. There was a company out west that did 4x4 conversions. Those converted couriers had solid front axles, they were sold as the Ford Courier Sasquatch.(Sasquatch_Ryda, I'm thinking it's time for a cab swap.lol)
If you're looking for a Ranger to go offroad with, the Twin-Traction-Beam is what you want. It's basically a solid axle that's built into two sections to allow for independent movement of both sides. It's equally durable.
so all of the old rangers that i have seen with solid front axles are custom? did ford make a compact solid front axle(bronco II, explorer) I realize thats probably a dumb question because, if they did, than it would have probably been used on the ranger but its worth a shot.
alright so i see the explorer started with the ttb and im asuming the broco II was aswell. This is my deal. I have the torsion bar front end and have been pissed since i got the truck basicly. I have put on about 60,000 miles and have had to replace 3 cv shafts and front hubs i have put on 3 pairs. I even tried the AVM or rugged ridge and they blew up as well. I understand that cranking my torsion bars up puts more wear on the cv joints but one going every 20,000 miles seems kind of alot. I did crank them towards the higher end. I think about 2.5 to 3". With the ttb lifted will that go through as many uv's im pretty sure i havent heard anything bad about the hubs. I just want something i can take down a logging road occasionaly and still get to work.
20,000 miles till failure is pretty typical if you've cranked the bars above 1.5-2" from stock.
Lifting a TTB suspension has no effects on the life of the axle u-joints (bigger tires potentially can though).
i would like to run 31s or 33s and i just wanted to say thanks to everyone for the info you guys saved me several hours combing the internet
crank your bars down an inch and go to a body lift for the clearance if needed...will probably solve your problem and give you the room you want
No midsize ranger ever came with a solid front axle...I have an 83 which is the first year of rangers and it's a D28 twin I beam...which I'm surprised how durable it is because it's such a small little thing...
