Just Plain Stupied
It had #64 original main jets........I replaced them with #60 jets & got 4mpg better on the highway & I can still burn rubber when I feel like it........
I'm gonna try smaller jets until the engine stumbles on accelleration....then I'll increase the jets size by 2 sizes.....I'm lookin for good gas mileage on long trips....I'll check the gas mileage soon & let you know what it is...(350 cu. in. bored .030 oversize...flat-top pistons....medium-rise intake....holley 600 4-barrel.....700R4 with 3rd & 4th gear overdrive....OEM 3:21 rear end....225-70R-15 B.F.'s on rear end)
if you don't need drag strip power you can actually lean out the engine quite a bit. Remember to check spark plug color: the more you lean her out, the more pale the color of deposits. If they are white, you are in danger of burning valves. You could try water mist injection to cool when running lean. Also keep an eye on tailpipe deposit colors.
an inline fuel pressure regulator set low can also help. just remember to set the pressure up when racing or heavy hauling.
Since your truck is so light, that SBC does not need a whole lot a gas to get her moving, so re-jetting the carb indicates a fella that knows what he's doing. Keep it up doorgunner!:icon_thumby:
float?.........to the Gulf of Meheeko?
thats what a few miles away?
gots to get the interior walls finished in the '36 first....then take that hitch offn the wall & fab a crossmember for it...
Dont forget the cup holders! say that boat have them? if not i might have an idea for you:icon_idea:
Just Plain  Stupied
Just Plain  Stupied
Coyote....you've got it! I just connected the main air supply hose for the water injection a few days ago...now I need to order an adjustable mister & a w.w.w.c.
the s.p.'s will get pulled & eye-balled today for color...
interesting cupholdrs....
DOORGUNNER!!!!!!!!!!!!!!!!!!!!! MY LONG LOST FRIEND
whats new with the ranger sine ive been out? do you have a sbc in her?
what's up boggin.........it's sbc'd/700R4'rd/4barreled/4,000 test miles so far/no interior upholstery yet/still gettin the bugs outta the over-drive/fixin to mount the gps for road-tripppppppppps/20mpg's in 4th gear(still waiting on consistent operation of O/D to get a mileage check)/fu-u-u-u-u-u-u-u-u-u-u-n to drive X's 10 !/scratched up the bed real good cause it's a Daily Driver!/etc.
its a 350 chebby thats .30 over!!!!!!!!!!!!! Now it needs a blower!!!!!!!!
DG if you like i could pick up a set of them cupholders if you cant find them down in teh big easy
3.7 x 3.7 = 13.69 x .030 = 0.41 x 8 = ........ohhhhh n-o-o-o-o-o-o-....it's now a 351 !!!!
Ima go to a boat dealership to get the swiveling cupholders....in case I decide to climb a few levees (you know...to get to higher ground)
hmm boat dealer somehow i was thinking there wasnt any in your area...thats a real sharp moment there eh
still dont have cupholders? werent we dicussing this when you first started the build haha
HYENNA
roflcopter
