Official RBV Tool and Part Kit thread
WNY964x4
ASE Master Certified
⭐Supporting Member
Firefighter
ASE Certified Tech
East Pembroke , NY
ok , so lets get an official RBV tool kit thread goin , as the posts go along i will update the list in the first post
Fell free to post up with more suggestions
The Official holyford86 Tool Kit , i think this covers all bases ( Slightly Modified to include other essentials , thanks to other forum members )
What I carry all the time:
1/4", 3/8", 1/2" socket sets, along with ratchets breaker bars, and extensions
Metric Sockets from 8mm-19mm
12mm 12pt Socket
Cheater bar
4-Prong Axle Nut Socket ( D28 , D35 , D44 TTB axles )
Multiple sets of pliers, wire cutters and vicegrips
a few different hammers
assorted screwdrivers
hydraulic jack
TFI wrench
snap ring pliers
wire
Heat shrink tubing
solder
soldering iron
small inverter
lighter
mag lite
assorted hardware
hydraulic jack
hi lift jack
20' of chain
tow strap
tree saver strap
ratchet tie downs
bungie cords
a few screw pin shackles
carb cleaner
brake cleaner
maf cleaner
wd40
zip ties
electrical tape
25' air hose
bolt cutters
shovel
hose clamps
assorted air fittings
fuses
light bulbs
relays
tire plug kit
air compressor oil
motor oil
mercon III
antifreeze
tire pressure guage/air chuck
valve stems
measuring tape
vernier caliper
Jumper cables
files
rags
DMM
winch controller
butane
fire extinguisher
metric, standard and adjustable wrenches
Stuff I will be adding to it soon:
air hammer/chisels
impact wrench
fuel pump relay
EEC relay
Test light
snatch block
starting fluid
sandpaper
I am also making a spare parts kit to carry sometimes, it will contain:
One complete set of axleshafts for the front
ujoints for front and rear driveshafts and front axleshafts
one hub
one spindle
one set of pre greased bearings (both sides)
2 front wheel seals
Belts
80w90
Grease gun/grease
Shran's Tool Kit
- tarp
- hatchet
- bow saw
- big knife
- small knife
- machete
- usually carry a chainsaw, 1 gallon of gas, and bar oil, and a scrench
- 4 way lug wrench
- mechanic's wire
- at least 2 quarts of every fluid
- tape
- rope
- 20' 4" recovery strap
- 2 d-ring shackles
- smaller recovery or tow strap
- high lift
- hydraulic bottle jack
- several short pieces of 2x4
- hammer
- cheater pipe
- lots of gloves
- ratchet straps, bungee cords, etc
- shovel
- jumper cables
- winch jumper cables
- rags
- spray lubricants & cleaners
As far as parts go -
- hubs - how many I carry depends on how many I have on hand
- front shafts - same as hubs
- TFI
- coil->distributor wire
- couple of front and rear u-joints
- 2.9 lower radiator hose
- battery cable ends
- tire repair supplies
Additional Miscelaneous Items
Rubber Boots
Reflective Rain Gear
Flares
Haynes or chilton manual
These full lists are examples of what to carry on a trail rig , if your truck is a daily driver , use these lists to form your own emergency kit
You might want to bring a socket wrench to use with the sockets lol jiust messing lol
duck tape
zip ties in many sizes
electrical tape
first aid kit
fire extinguisher
TWO, yes, i said TWO pairs of pliers...
TWO, yes, once again, TWO knives (folding or fixed blade)
Pliers are a no-brainer... so are the knives, everyone should have a folding knife with them all the time (if the law allows, of course).
Also a couple fire extinguishers may be good, I know the person above said one, but, one is none, two is one, etc.
what do you guys think about tire plug kits and starter fluid for your tires when they come off the rim
The plug kits only work good on a small puncture like taking a nail to the tire. The starter fluid trick works pretty good, I've seen it done before.
Some sort of tire pump is usually handy.
10mm socket
I have more to list but I'll have to do it later
the number 7. I always have one handy.
Cellphone and cash for the wrecker.
