Official RBV Tool and Part Kit thread
Hi-Lift jack...
Hydraulic (Bottle) jack...
how about a camera to take pictures of the chevy or dodge your about to pull out of somewhere they shouldn't have gotten stuck in???
What I carry all the time:
1/4", 3/8", 1/2" socket sets, along with ratchets breaker bars, and extensions
Multiple sets of pliers, wire cutters and vicegrips
a few different hammers
assorted screwdrivers
hydraulic jack
TFI wrench
snap ring pliers
wire
Heat shrink tubing
solder
soldering iron
small inverter
lighter
mag lite
assorted hardware
hydraulic jack
hi lift jack
20' of chain
tow strap
tree saver strap
ratchet tie downs
bungie cords
a few screw pin shackles
carb cleaner
brake cleaner
maf cleaner
wd40
zip ties
electrical tape
25' air hose
bolt cutters
shovel
hose clamps
assorted air fittings
fuses
light bulbs
relays
tire plug kit
air compressor oil
motor oil
mercon III
antifreeze
tire pressure guage/air chuck
valve stems
measuring tape
vernier caliper
Jumper cables
files
rags
DMM
winch controller
butane
fire extinguisher
metric, standard and adjustable wrenches
Stuff I will be adding to it soon:
air hammer/chisels
impact wrench
fuel pump relay
EEC relay
Test light
snatch block
starting fluid
sandpaper
I am also making a spare parts kit to carry sometimes, it will contain:
One complete set of axleshafts for the front
ujoints for front and rear driveshafts and front axleshafts
one hub
one spindle
one set of pre greased bearings (both sides)
2 front wheel seals
Belts
80w90
Grease gun/grease
now added the aptly name holyford86 kit to the first post
matches, lighter.....dont think i saw that anywhere
I think the most recently added one is the most important :)
hydraulic jack
TFI wrench
snap ring pliers
wire
Heat shrink tubing
solder
soldering iron
small inverter
lighter
mag lite
assorted hardware
hydraulic jack
hi lift jack
20' of chain
tow strap
tree saver strap
ratchet tie downs
bungie cords
carb cleaner
brake cleaner
maf cleaner
wd40
zip ties
electrical tape
25' air hose
bolt cutters
shovel
hose clamps
fuses
light bulbs
relays
tire plug kit
air compressor oil
motor oil
mercon III
antifreeze
valve stems
measuring tape
vernier caliper
Jumper cables
files
rags
DMM
winch controller
butane
fire extinguisher
air hammer/chisels
impact wrench
fuel pump relay
EEC relay
Test light
snatch block
starting fluid
sandpaper
one hub
one spindle
2 front wheel seals
Belts
80w90
Grease gun/grease
:icon_thumby: im putting together the same list. you forgot a spare air filter,wiper blade,and a decent sized tarp.
It may be for my job but I think its good stuff to have
2x cones for the side of the highway
Hydraulic Jack
Jump Pack
12v Air Compressor
Fire Extinguisher
18v Cordless Impact w/ a set of deep impact sockets
Vehicle Unlock Kit
1x 25' Strap w/ hooks
1x 30' Strap
3x 1,000lbs. Ratchet Straps
2x Bungee Cords
Oil, Trans, Coolant and other misc. fluids
2x Flashlights
1/4" Socket set metric and standard
1/4" Ratchet
Breaker Bar
Screw Driver with interchangeable bits
2x adjustable wrenches
Assorted pliers
Phillips and Flathead Screwdriver
Wire cutters/Strippers
PB Blaster
2 gallon gas can
Rubber Mallet
3lbs. Hammer
Gloves
and most importantly SAFETY GLASSES!
I think that's all of it, and also, you should always bring a towel :icon_thumby:
