- Apr 10, 2008
- Northern Michigan
Well, I learned that when you raise the bed floor it is very important to make sure you have a tailgate in place and all the gaps are good and lined up. I didn't do that and ended up spending a week getting the driver bed side corrected.
I tried to just crank the box side over with wratchet strap but it didn't correct anything because it was just pulling the bed floor over. So I made a gusset and welded the bed floor to the pass side of the box. This held the floor in place.
Then I hooked the strap between the top of the dr bed side to the bottom of the pass side. The gap was only excessive at the top of the dr side. I cranked it straight and welded in the gusset on the dr side. Problem solved. Now the pics....
