My factory setup had a metal line with rubber ends.
To convert to just the rubber hose, all you have to do is use a different fuel filter with a male rather than female end. Then it's just a hose clamp at the carb/fuel filter and one down at the pump.
$5-$7 for the filter, hose, and clamps. Then the angle of the metal line, threads, etc. are not critical. You just need to make sure you get fuel line hose so it doesn't disintegrate, but any parts store will have spools of it. High pressure hose is not required since this is for a carb application.
But the exit from the fuel pump is female. I purchased these fittings making them both male, then ran a worm clamped rubber hose between the two. I am leaking fuel at both places from the fitting connections.
I will buy this male ended fuel filter, but what should I do about the fuel pump connection (which is why I would like to know the correct fitting size, as the one I "thought" fit apparently did not!).
Thank you!
