- Dec 3, 2009
93 Ranger XLT. 1/3 drop, custom paint, American racing polished 5 spokes, 28x11-15 rear rubber, factory composite leaf springs, welded custom roll pan, euro taillights, vent visors, 408w stroker, 94 factory roller block .030 oversize clearanced down bottom, scat crank, probe forged lightweight rods, probe forged pistons, custom comp cams hyd roller cam , scorpion roller rockers, AFR 205 heads, dual valve springs, long tube headers, double roller timing set, Melling std volume oil pump, ARP bolts + oil pump d/s, MSD distributor, 6AL ignition box and blaster2 coil, Edelbrock Air gap intake manifold, ford racing oil pan kit, felpro hp headgaskets, proform electric waterpump, powermaster 1 wire alternator, holley 670 street avenger carb, holley fuel pump and regulator, Duff radiator, 2 electric fans, welded aluminum valvecovers, zoom stage 3 clutch, tremec 5spd, hydraulic external slave cylinder, 8.8 31sp 3.55 lsd rear end, coil overs in the rear, my own tucked wire harness, braided fuel hoses, yellow top battery located behind glove box door. ...... I think i got most of it. Vote for me TOTM
