My 93, pics and specs.
93yellow408
93 Ranger XLT. 1/3 drop, custom paint, American racing polished 5 spokes, 28x11-15 rear rubber, factory composite leaf springs, welded custom roll pan, euro taillights, vent visors, 408w stroker, 94 factory roller block .030 oversize clearanced down bottom, scat crank, probe forged lightweight rods, probe forged pistons, custom comp cams hyd roller cam , scorpion roller rockers, AFR 205 heads, dual valve springs, long tube headers, double roller timing set, Melling std volume oil pump, ARP bolts + oil pump d/s, MSD distributor, 6AL ignition box and blaster2 coil, Edelbrock Air gap intake manifold, ford racing oil pan kit, felpro hp headgaskets, proform electric waterpump, powermaster 1 wire alternator, holley 670 street avenger carb, holley fuel pump and regulator, Duff radiator, 2 electric fans, welded aluminum valvecovers, zoom stage 3 clutch, tremec 5spd, hydraulic external slave cylinder, 8.8 31sp 3.55 lsd rear end, coil overs in the rear, my own tucked wire harness, braided fuel hoses, yellow top battery located behind glove box door. ...... I think i got most of it. Vote for me TOTM :icon_thumby:
hey looks good, two questions though...what you have for rear end? 4 10s? 3 83? and secondly...why did you go with the AFR 205s? i bet you would have got a lot more out of a set of AFR 225s.
damn thats a sick truck!!!!!! but yea it could be a little lower but still awe:icon_hornsup::icon_cheers:some!
sweet truck. when you say probe you mean ford probe right?
The 205 head allows plenty of breathing and is very good for the street. A larger head may get you more peak hp but may be a little less on torque. This engine makes a ton of power and doesnt need to be turned up to 6000rpm. Built for torque, dual plane intake, custom cam and the cid all equal torque numbers. Others have opinions that i could have gotten more hp with the victor intake and 225 heads and not had any issues with driveability since its not a heavy truck. I would rather have the torque then 40 more horse tho. Its estimated a good amount over 500hp and have bigger torque numbers. Plenty... I assure you i did tons of homework before i started, 205s were what was recommended.
thanks for the comments guys! oh yeah.. and im running 3.55s
and for the height.... well, i live in maine where the roads are not pretty and have 3" exhaust and long tube headers stuffed under there. could maybe go another couple inches tho. If i had time to work on it i would pick away, its a never ending project.
Downey, probe is the manufacturer of the components, its not from a ford probe. http://www.probeindustries.com/ ,I think it may be made by coast high performance out of california.
Don't lower the truck. Leave it as it is, no one will have any idea what you have under the hood. At least until you hit the gas pedal :). Nice truck, I wish I had that engine for my Bronco II
he means probe industries their got some awesome ford stuff
AND THAT IS A SICK NASTY TRUCK
hey, i get what youre saying, makes sense since oyu have a dual plane. We built a 427W for a fox body, and used a set of AFR205s. It has a single plane though, and there isnt quite enough airflow AFAIC, would be better with the 225's. For your application it makes sense. Good call.
Oh and i see youre running a t5, what clutch you using? in the future when you blow it up (LOL) you may want to try a TKO600, weve had good luck with that tranny.
yeah, if you run high rpms a bigger head would work nice for more airflow. I have the HD 5 spd with no issues yet! Zoom stage 3 clutch.. not sure if its holding very good tho :icon_confused:
sleeppppppppppppper :) good work, dude. not a soul will think twice of that truck til you toast their asses on the drag.
How do you have it dropped 1/3? I'm just wondering because in the pictures it looks totally stock, unless you have small tires or something.
