- Jul 7, 2009
- Loganville GA
thats the way i do my body work. i just use rust defender primer, the body fill. rust defender, then i use this product called iceing, its a polyester glaze that goes on super thin and fills little imperfections in the body works. then i just coat the iceing with you standard laquer primer. the reason i use laquer is it dries quick, sands easy, and doesnt build up much.
then i do my base/ clear.
The only bad thing about laquer primer is it is porus... Try rubber seal 2K primer.. it dries fast and you can reduce it if you want it thin...
http://www.rubber-seal.com/
