update new temp gauge is in thus far it on short trips runs under 190. will update after a longer trip.
The oil pressure gauge is easy to set up...you just remove the stock sending unit from the engine, and screw in the hose and fitting into the hole it was in. The new gauge should have come with the right fittings to do this.
