Odd Dog
- Oct 20, 2009
First let me say great site, just found it.
I bought a 1990 ranger x-cab 4x4 with a 2.9, it had a small tick, so I figured I'd give her a quick tune up, and an oil change, she'd be good togo. When I pulled the drain plug nothing came out, the oil was that thick, never been changed in a long time, and I think theres a little anti freeze getting in as well, anyhow, after reserching here, and seeing how dirty the inside of my engine is, I'm thinking gummed up oil passages are an issue, today I tore down the top end, and timing cover off, so I have a couple of questions. How much play should there be in the cam bearings,(I suspect this is another problem) how do you gauge it? How much play should there be in the timing chain? I have a noise(rattle) at about 2200 rpm, its not the rocker arms, thought it might be lifters but and adjustment stopped the tick, but the internal rattle is still there, so I'm thinking timing chain, possible camshaft, haven't got it out yet I'll keep you posted and thanks in advance for the help.
