Full Width SAS on '90 Danger the 4th
Bumper Continued
Worked on the bumper a bit tonight
Borrowed a chop saw from work. made life easier
Doing well with the buzz box tonight
Buddys that owns the welder's Build. 4 link D60 on a 1991 GM
Coming Along
hey dude good work so far, and i cant wait to see how things turn out!
are you gonna shorten the axles at all?
Thanks!
And no. i am leavin them full width! its gonna be sweet. I think lol. But i have to come up with some kind of flares. Ohio law states no more than 3" of tires can stick outside of the flare. I know this is going to be an issue since i want to drive the truck daily. I just got a ticket for tinted windows and no front plate on my powerstroke so i know they are not going to like the wide stance. but i will figure that out when the time comes. Plus the bumper height is going to give me issues. I will have 2 trucks that are asking for tickets... hmmm i gotta make one of them a smaller distraction some how lol
**ALSO UPDATE:**
I bought a ring today. Wallet is light now but its all good. This means i can start buying parts and get this build rolling! :icon_bounceblue:
And If you know who i am, dont tell anyone. no one knows yet. well, except trs
I am been slacking. Sorry guys. I have been pre-occupied with other projects. The guy that bought my 79 couldnt pay me so i repoed that and have been trying to get it road worth so i can get a little more out of it. Plus its been raining here a lot which hurts motivation to work... until i see mud holes :D
I have my new spring perches, shock mounts... that need to be set and welded to the rear axle. I hope to accomplish that this weekend. As well as finish my bumper. I also picked up a spool for my front D44 for $40 :)
where you getting the shock mounts from? love the build
i found them on a local 4x4 forum. They were new and cheap :D
I have heard of some people getting them from Ford
**Edit**
Found a FORD part number on them
Finished Bumper - except paint
I pretty much finished the bumper this weekend
Sanding it down to the weird angles
Test Fit
Trimming
Test Fit, Ready for welding
Top View
Bottom Corners Welded
My Frame comes up at an 8 degree angle. I took angle iron and cut it at 8 degrees. I welded that end to the bumper. I am using existing frame holes to line up the holes in the angle iron for attaching to the frame.
I clamped them together and grounded them until they matched
All welding was arc - I dont have a welder, so i have to use friends dads, which have the old school stick welders. But i am glad i learned how to weld with one
Bumper was built for a grand total of under $50 not includeing paint.
That 50 bucks includes the steel, welding rods, cut off wheels, D-Rings, and 2" receiver! Beats paying $450 for one. Although this one ended up being a little heavier than i wanted. but its all good
Bumper C Clamped to frame
Its going to be pushin in another .5" towards the truck
What the weekend entailed of :icon_thumby:
Rear axle pics will be posted later today
Question
What do you guys think about putting this mesh behind the gaps??
8.8 Perches and Misc
finally got some sunny days here in NE Ohio
Took my org 7.5" and new FW 8.8 to a buddies because he has welding stuff.
The 7.5 Compared to the 8.8
I shimmed the pinion on the 7.5 until i got 0 degrees on the perches. Then i measured what the pinion angle was and set up my 8.8 to have the same pinion angle. However, i added 2 degrees due to the large lift i am doing. I made sure that that would allow enough oil to get to the pinion bearing with out foaming. It should be good.
Then i measured the perches and carried those measurements over to the 8.8. I double checked by measuring from the perch to the drum back plate to make sure my axle would be centered.
The Perches are for an early bronco from the bronco graveyard. That gave me the right tube diameter and perch width.
Welding didnt go as smooth this day, but they will hold
My front body mounts have been disfunctional for 2 yrs at least. the Cleveland salt has taken its tol on them plus i used to plow with it. So i am going to cut them off and use some large angle iron i found to replace them. Also the rivots are in the way of my bumper so the new ones will be welded on.
Pass side off:
The replacement
Getting these off allowed my bumper to fit where i wanted it. Although i know i will probably hit something have have the corners smash my lights. but rangers/exploders are plenty full in NE ohio junk yards
Trying to keep my arrival angle the best i can
It started to get late, but i started to tear my D44 down a little bit. it needs a good cleaning
Track bar removed
I found some 5.13s on craigslist for it. I wanted 4.88s but 5.13s work. I am picking those up on saturday. He has 9" ones too. might just get those too and build a 9" later. 8.8s are just so much cheaper. Also found 15x10s near by. Waitin on what the backspacing is on those. I have to pick up the front spool i got too. Its coming along....
u gonna do the mesha different color then the bumper? liek bumper black and the mesh the body color
________
CANNABIS SEEDS
