- Aug 7, 2007
- Saginaw, MI
Fram?? There you go...junk
Well, figured that part out. Now it seems that the oil pan is leaking or something else from that area, not the oil filter. Drove it for a while, seemed like the oil gauge went 3/4 and then dropped tro 1/4 and oil started to leak from somewhere else. Maybe the compression got so high it needed to find a way out? Hell, I don't know. Seems to run fine otherwise.
I will have to get it looked at to track down the new leak and possible cause if it is something else that will keep causing a leak. Very frustrating. This leak looks like it is near the oil filter and the oil runs down the oil pan rear edge along the bolts edge/lip of oil pan are and then drips down.
I will look at the gasket between the oil pump and the block. To get to that, how do I go about it? do I have to completely remove the oil pan and if so, looks like a huge pain in the arse! Do you have to lift the engine up a bit for that?
Thanks guys
I believe it was a Fram filter
that happened to me as well - same problem, same filter
the filter failed spectacularly - it wasn't double gasketed. just a bad filter. no post-failure engine problems, but it happened while i was still on the driveway
Fram filters have been used on all my families vehicles for years and never had a problem. Had problems with other ones leaking but never had a Fram leak on us yet.
