doorgunner
Lab Rat for V.A. hospital
2009 Truck of The Year
MTOTM Winner
- Oct 22, 2008
- Total Lift
- N/A
- Total Drop
- 3/4
- Tire Size
- 23570R15
- My credo
- JESUS Loves Ya!
Note to me: use whitetrashdoc's crank-start idea/modify it by using a Ford crank-handle thru the lower radiator grill w/spring-loaded switch wired thru neutral safety switch to starter solenoid/switch to stay activated as long as handle is cranked(just for fun).
Note to me: check out FatMat sound deadening (recom'd by blackwidow67).....check
Note to me: install adjustable thermostat to electric fans.......(waiting on sbc swap)
Note to me: use return regulator w/fuel pressure gage b/twn carb & oem regulator.....(waiting on sbc swap)
Note to me: undercoat all body parts before assembling........check
Note to me: Rotate/ shim rear axle to match angle of rear drive shaft to stop differential from
bucking on take-off
Note to me: order door seals & fender-to-body & hood-to-body anti-chafing gaskets
Note to me: wire & install back-up lites............................check
Note to me: buy a fancy gas cap lid to put in the bed floor......WHAT???.........check
Note to me: don't mess with the new Moderators.....check
Note to me: center wheels in wheel-wells.....check
Note to me: install rear air-shocks................check
Note to me: re-connect 3 vacum lines................check
Note to me: weld support plates & tubing to ends of roll bars under cab & bolt to chassis
Note to me: add 2" thick soundproofing through-out cab before installing inner walls
Note to me: splice in remote start/alarm/doorlocks b4 wrapping/tucking driver's side wiring under dash......check
Note to me: test out oem versus Classic sending unit BEFORE installing in the tank (b-b-bo-o-o-m-m-m-m)
Note to me: check out web sites for motorcyle turn sig's for front bumper (for Honduras)
EDIT: just re-locating to-do list b4 I forget about it......LOL....(seriously)
