- Jan 7, 2009
i have arms off a 70's f-150. and i have cherokee 3in coils so i should be good to go
Well heres the thing. I got the D30 and D35 for free. The gearing on the D30 and D35 are the same (4.56). The D35 has a detroit locker, new bearings, new seales, new gears, in other words $400 worth of work done to it. The D30 does not have the vacuum lock (CAD) on it.
As for the drive shafts I dont care if I have to shorten them or lengthen them, I know im going to have to do that and I'll just take it to a drive shaft shop for that. I was just worried about the u-joints being the same size.
Thank you so much if you have anything else to add that I might have forgotten , please add it.
A D30 swap into a 2WD Ranger isn't too bad, replacing the already stronger D35 with a D30 is nonsense... Replacing the MUCH stronger 8.8" rear with something that is unreliably weak in a much lighter vehicle is even more nonsense...
