2.5 ton 85 ranger 18.4x30 tractor tires
np435 trans 6.68 1st gear and t-136 transfer case 2:1.........89.78:1 crawl ratio
I might be cutting the centers out so I can weld them into the tractor rims but if I dont I'll let you know.
you can have them when Im done. only 2 are good enough to use though other 2 are peeling
heres some more pics of some updates tire comparison 33x12.5 on the outside 18.4x30's, also got the bed off to build my rear shackle and mount
whats the point of the sub frame(truss or whatever you want to call it) if its not linked? i know theres other ways to re-enforce the frame without taking away so much clearance.
just curious.
By the time those tires are on the axles they'll be well over a foot away from any body panels.
yep. :icon_thumby:
just curious.
It is going to be linked. not a 4 link but I will have link bars to keep the axles from wrapping. Also for the simple fact that I wanted to be sure the frame was not going to twist. I will have about 2800 lbs of un-sprung weight and I dont want thing breaking. I dont think I will have a clearance issue as the bottom of the subframe will be at around 48". I also built it so that one day when I have $5000 for coilovers and 4 links I can do that. :icon_cheers:
yep. :icon_thumby:
sounds like a plan my friend
Upcoming TRS Events
Featured Ranger Based Vehicle
