very nice, i good friend of mine uses a 5 axis router at work, he has made some pretty cool stuff out of mdf for me a few times
keep in mind that i'm not making a competition product, its just my daily driver.
i'm also not building this box around a specific sub, its specific to my car.
just for reference, the speaker in the illustration has a 4-1/2" mounting depth and a 4" diameter magnet. (just realized that the mounting depth i used for mock up isnt very deep) its a 10" sub with a 9" mounting hole. the internal volume is 1248 cubic inches, or about .72 cubic feet per speaker,
Um baxtej44, you only really lose 3/4" of an inch cause your sub mounts to the outside of the box.
think so? so 3/4" or more of the sub is on the outside?
what number is without the part that is outside the sub then? top mounting depth or bottom mounting depth?
some sites only have one, some sites have both... so i'm confused!
sub mounting depth is measured from the back or the rim to the end of the mag. so part of your mounting depth is eat up by the thickness of your box material.
Woofer Frame Outer Diameter* (A)
Woofer Grille Tray Outer Diameter** (B)
Woofer Magnet Outer Diameter (C)
Frontal Coaxial Tweeter Protrusion*** (D)
Woofer Frontal Grille Protrusion**** (E)
Woofer Mounting Hole Diameter (F)
Woofer Mounting Depth (G)
from the outside of the front face of the box, to the inside of the rear face. i hope that makes sense... your speaker mounts to the outside of the box, but the magnet will hit the inside of the box if you dont have enough room. so for the box, if your max depth overall is 5", and you are using 3/4" mat'l, you have approx 4-1/4" max mounting depth.
well maybe my box will work out anyway
i scooted my passenger seat up to see how much room i could get behind there while still being somewhat comfortable
9 inches deep at the bottom
5 inches at the top
13 inches tall
about 20 inches wide...
how does that sound?
if your box internally is 5 inches you really have, 5.75 inches useing 3/4'' mdf.
maybe just a different way to say it.
doesnt sound too far off from mine, and mine has fit both of the 2 different subs i have test fit in it. you can always get shallow mount subs too. how does it come out as far as volume?
i'll start looking around now for mounting depths no bigger than 6 inches, as I would say 6" is being too close to the back of the mdf, correct?
6 is still a really close number but there are alot of subs that are 5'' 5 3/16 ect.
