- Mar 14, 2009
- Eastern NC
- 1996 & 2000
That sucks for sure! Sometimes ya gotta pay to play! I hope you at least had a blast (pun intended) while doing it!
how many miles where on that engine?
that sucks... but at least it gives you another project
It was in someone's sig.
Exactly how deep was this water? Seeing your Ranger is a 97, that means your airbox intake is probably the same as mine. I've driven through flooded roads that come up to the frame at speeds of 15~25mph. Never had a problem with water ingestion.
the water way up to the top my bumper and after the truck died it went a little further
I dont understand how a starter will do more damage than a running engine. It was likely fawked before he tried starting it.I think you shouldn't have tried to start it. If you ingest water and the engine stalls, you need to pull the plugs before trying to turn it over to clear the water out of the cylinders. Otherwise you get what happened to you, something has to give as the water won't compress.
i fixed that problem today i made a snorkel to go right into my cowl
i also found out that i cracked the block after pounding out the pistons
i'd still drive it like that
