- Nov 30, 2001
- Gnaw Bone, Indiana
Opinions vary of course.
I thought the modulars were awesome when they first came out. I still think they're a very solid engine, and have seen quite a few with 250k and run like they're new. But they have suffered their share of issues. Shooting spark plugs, cracked exhaust manifolds (ever notice how all the high mileage 5.4 F-150's all have the same exhaust leak?) exploding intake manifolds (4.6L cars), and terrible valve seals (92-94 crown vic's) are some of the things that come to my head. And $60-$80 per coil times 8 cylinders is a bit rediculous when 2 coil packs at $40 a piece works just as well. And what's with having to remove the fuel rail to get the spark plugs out? That's retarded. And having to tear the front end off an otherwise perfect shape motor to replace the timing chain tensioners that ford decided to make out of plastic? That's also retarded. From a "having to work on it" standpoint, I'll take a 300 anyday.
I would take the 300 6 very durable. U want to turbo the I6?? Check out this info...
TC DOHC I6
415.54959785629995 hp at 5500 rpm
416.67 tq across the range from 1950-5200 rpm
VS.
5.4 dohc boss v8
422 hp at 6500 rpm
406 tq at4750 rpm
The I6 has the v8 beat in the tq curve. The I6 is a flat tq curve i mean 416.67 foot pounds at almost 2000 rpm that is some serious power! The v8 beats it by only 6.46 hp and u have to go 1000 more rpm to reach it...... The I6 makes its tq all the way to 5200 rpm.
slap a aftermarket head a good intake and exhaust and a 4bl carb and you have a really stout engine that would suprise alot of people
The same goes for about any other engine as well...
My personal opinion is that the 300 is a pile of shit and I could care less if I ever saw one again unless it was free or very close to it. I have owned three and all three are down for the count. One threw a rod at 120k, the second lost oil pressure and died, and the third ran but had a really bad knock when I sold it.
I don't know why you guys have a problem with gas mileage in 300s and 302s. 300's were advertised at 21/27 and my 300's would do 20/22. I have never calculated what I am getting in the F150 but it doesn't seem too bad..
Really? Thats hard to believe. The 300 is ussually expected to last atleast 300K.
