Instrument Panel LEDs
i bought the WLEDx4 which is the one that shines brighter in your pictures everything is blue on my cluster including the needles but the lights are so bright i have a couple hot spots (which i dont mind i think they look cool kind of like camo)
I bought just the regular LED bulbs and they worked out fine in my dash (1987)
sweet now your all blue im thinking about doing my dome light too i have some bright white ones in they look cool but i want to put a 3rd one in thats blue
I got me a crusty 88... does the green film come off with nail polish on these as well???? thanks for the help...
Damn, I'm getting ready to do an entire dash swap when it gets warmer. Since I have to swap clusters anyway, I think I'll have to do this. As someone else said, this never even occurred to me until I read this ENTIRE 9 page thread, but now I'm hooked! I may try a white face, too, just for sh*ts and grins. I'll post pics whenever I can.
SCREW IT! here's mine....
Cluster has 36 5mm 13000mcd LEDs. HVAC has 9 5mm 13000mcd LEDs. Fog, headlamp, and 4x4 switches each have 1 5mm 13000mcd LEDs. Cruise pods each have 2 5mm 13000mcd LED's.
Hot spots are not that bad in real life, pics make it worse than it really is. I have NO PROBLEMS seeing my needles in my Expo cluster.
Link to my build up...
http://www.ranger-forums.com/forum2/showthread.php?t=62796
so i put my lights in the other day and i'm somewhat disappointed with the result. the needles and odo shine bright blue like they should but the light barely comes through the numbers and they're still greenish. it's kind of growing on me to have bright blue needles and dim numbers though. looks kind of cool. but the question is, should i return them and get some that have a wider light diffusion or should i go with the current look? here's a before and after picture...
BEFORE
AFTER
kind of crappy pictures, but you get the idea
You need to take apart your cluster, pull the needles, pull the 'overlays' off, wetsand the green away, then put it back together, or paint on some glass paint to manipulate the colors through.
Plug in LEDs in your clusters SUCK! Believe me...i tried before I went ahead an went with all component LED's.
like this:
Not to sound stupid, or anything, but what do you mean by 'component' LED's?
EDIT-Nevermind. I got off my arse and looked it up. How did you wire them up, out of curiosity?
Solder. lol.
this is very innovative.
you should consider getting a film from a craft store to put on the back of your new clear openings.... then you just need to super glue around the edges and you're good... and if you ever want to change the color it's real easy.
just an idea.
