At 55 in OD with 3.73's you should be about 1800rpm... If you did lose OD you will be running at 2400rpm... I don't think that's your problem though... running at 2400rpm instead of 1800rpm at 55 will increase your gas mileage, not decrease...
1300rpm for 40... Just put it in D and drive up to 40, then move the shifter lever to OD... You should hear it drop into OD and can watch the tach drop down... Like I said though, you would only get better gas mileage by running it in D...
Oh, I assumed you have 3.73 gear ratio, so if my numbers are a few hundred off it's nothing to be worried about, it just means you have 3.55's instead...
I had an 86 ranger and at the time I had it (I was 16) I didn't realize it but the torque converter was slipping reallllllly bad and it ran 3300 rpm at 70 mph in OD.
Drive is 1:1 (every time your engine turns once, your driveshaft turns once) Overdrive is 0.75:1 (every time your engine turns 0.75 turns your driveshaft turns once)
You will get better gas mileage when you can keep your engine in it peak torque range (2600-2800 for the 2.9) Therefore at 55mph your engine will be operating more efficiently in D than OD... Though at 70mph OD would give you better fuel economy...
I still think this is a CTS problem... You wouldn't get this bad mileage if you didn't have OD...
I would just leave it in OD unless you plan on driving at 55mph for a long time... Switching back and forth won't be worth it for a short jaunt... Honestly, I haven't even gotten back to my house yet, haha... I'll get that stuff to ya tomorrow afternoon...
lol well how would i know if something is wrong?
and ya... sounds like you're speaking german to me.. anyway, any links out there that can explain that.. with pictures and such?
Your Chilton's or Haynes manual, if you have one, will tell you how to test it and replace it. You need a multimeter to test for resistance, I believe.
Mine with 3.73 gears and 215/70 tires hits about 2600RPM at 70MPH in OD. FYI.
No it's not, there is maybe a 1MPG loss. Ranger's fuel economy didn't drop 5MPG when they switched to live axle![]()
